Hello everyone,I updated my ArcGIS version from 9.3 to 10.0, and now I have always an error when application is closing:The instruction at "0x7c90100b" referenced memory at "0x294e0a24". The memory could not be "read". Click on OK to terminate the program.I have read that I can solve this error with the following code: protected override void Dispose(bool disposing)
try
IStyleGallery styleGallery = new StyleGalleryClass() as IStyleGallery;
IntPtr pointer = Marshal.GetComInterfaceForObject(styleGallery, typeof(IStyleGallery));
Common.GIS.GISUtil.releaseCOMObjects(styleGallery);
//Close the ARCGIS map license
ESRI.ArcGIS.ADF.COMSupport.AOUninitialize.Shutdown();
GC.Collect();
GC.WaitForPendingFinalizers();
catch (Exception e)
Common.Utilities.LogFile.appendLine_error(e);
finally
if (disposing && (components != null))
components.Dispose();
base.Dispose(disposing);
This Dispose method is the main form's method. However, I am having the following exception on the first line (creating the StyleGalleryClass):System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {AC0E9827-91CB-11D1-8813-080009EC732A} failed due to the following error: 80040154So I can not solve the problem, and I don't have any idea of how to avoid the memory error.Does anyone have any idea? Thank you very much in advance.
