The process was working fine where we were useing MS Access DB (.accdb) by adding a OLE DB connection and then exporting the table to point features.onto the Map.
However, after applying the new patch 2.9.5, the process is causing ArcGIS Pro to crash. we are able to add the OLE DB connection and able to see the table in catalog pane, however when we are trying to drag and drop the table into the contents or trying to export it, the application is crashing.
Kindly look into the issue and let me know if you need further information to recreate the issue.
