Hello experts,
We have some 360° panoramic photos along streets. We used Experience Builder to create a viewer with Oriented Imagery widget. We came across a weird issue. The green dots indicate the camera locations. In the forward (vehicle moving) direction, they are in the air, not on the ground. However, in the backward direction, they seem to be on the ground, which was what we expected (see attached). Even though I changed the value of AvgHtAG from default 2.5 (m) to 0 (m), there is nothing happened to the green dots.
When I added images to OIC, I chose “Terrestrial 360 Camera” as Imagery Type. Do you have any idea what parameter I can adjust so that the green dots will fall to the ground?
Charles Deng
