I am trying to create a database connection in ArcGIS Pro to Snowflake using SSO. I have successfully created an OLE DB connection to view my tables, but I'm unable to view their spatial component.
The solution would be to create a database connection and then a query layer, but within the settings to create a db connection under 'Authentication Type' it is only possible to select 'User' - which requires a username and login (not possible via SSO).
This is confirmed on Esri's help page - "Only user authentication is supported when you connect to Snowflake from ArcGIS."
Is there a possible workaround to accessing my snowflake data through the database connection option? If not, how can I view the spatial component of my tables that have geography fields?
Info: ArcGIS Pro (v3.0), Enterprise (10.9.1)
