I have a raster dataset of mean precipitation values, which I would like to group into classes and then convert to a shapefile. When I use reclassify, the output dataset only contains a row for the highest class (5001 mm to max value). When I use reclassify field, only the highest class rows have a valid value in the reclassified field; all other rows that apply to lower classes, contain null values in the reclassified field. I can't work out what the problem is - please help! [ArcGIS Pro 3.0.2]
