Currently when exporting an XML Workspace that can only be done to the C-drive as per ESRI support. As more organizations move to secure Desktop-as-a-Service (DaaS) and virtualized application delivery not all users will have a traditional C-drive. Allowing ArcGIS Pro to export these files to a shared drive or UNC location would solve this issue.
That screenshot shows that you're trying to write the xml into a file geodatabase.
I don't see any documented information about the output location being limited to the C: drive. https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/export-xml-workspace-document.htm
If you try writing your xml output to a folder on your E drive (not into a file geodatabase) does it work?
I actually got it to work after upgrading to the newest version of Pro.
Thanks for the follow up. Glad it is working. Closing this idea.
Melde dich an, um Beiträge zu veröffentlichen, Inhalten zu folgen und mehr. Neu hier? Registriere dich kostenlos.
