Using ArcGIS Pro 3.0 and ArcGIS Enterprise 10.9.1, postgreSQL database registered to the server.
When publishing Trace Network service to arcgis enterprise, received the following errors:
- In Share As Web Layer GP tool messages (attached picture): Failed to update the published service with server-side data location.
- In ArcGIS Server log messages (attached picture): SwizzleService Failed. DoAfterSDExtraction failed. CreateServiceWrapperfailed. Updating the server connection string for layer failed. Please verify the data exists on the server.
- In ArcGIS server DataValidator log (attached picture): The connection property set was missing a required property or the property value was unrecognized. Invalid connection property. []
I've checked that the database was properly registered to server, was able to publish a normal feature class from the same connection string and same feature dataset to the portal. Also digged deep into the server logs but couldn't find anything else useful.
While troubleshooting, I went back to use Pro 2.9.0 and set up another trace network dataset, and had no issue publishing it to Enterprise 10.9.1.
I repeated the process several times: uninstalled Pro 2.9.0 and re-installed Pro 3.0, the issue was there; uninstalled Pro 3.0 and re-installed Pro 2.9.0, the issue was gone. A new trace network dataset was created every time to do the testing using a script tool (automated trace network dataset creation and data import).
I read that Trace Network created in 3.0 does not work with 2.x. (link: https://pro.arcgis.com/en/pro-app/latest/get-started/migrate-2x-to-3.htm). Does it also mean that it can't be published to Enterprise 10.9.1? Any idea?
