Good afternoon everyone,
I created a model identical to another which works perfect in Arcmap. The model exports the result of a Vehicle Routing Problem to the connected geodatabase which, in turn, updates the company's SAP information. However, in Arcmap it works great because it does that process, but the same model in ArcGIS Pro doesn't.
The model runs without errors but it does not update the SAP information, it seems that it is a problem of connectivity to the geodatabase but it is also strange because in another different model, the information is downloaded from there without problem. The inconvenience is presented in the reverse direction to upload the information.
Perhaps it has to do with the type of path to the geodatabase that Arcgis Pro uses since it is located on the C drive plus the Windows user, unlike Arcmap which connects without specific route. I've tried adding the database file to the model from Favorites and it doesn't work either.
If anyone can help me, that would be awesome because I really don't know where is the error located, thanks.
PS: The connection to the database is done through Oracle.
