So my potentially dumb question is really three potentially dumb questions, but they all have to do with the FeatureTable, so hopefully asking all three of them in the same place will be OK.
I have things set up properly, I believe, as I can click the Feature and the data will show up in the FeatureTable, but the Feature doesn't highlight, and it doesn't register as actually selecting it. (It shows, Features: 1, Selected: 0). The way I'm doing it is as follows:
view.on("click", (evt) => {
var mapPoint = evt.mapPoint;
featureTable.filterGeometry = mapPoint;
This takes the geometry from my MapPoint and makes the feature show up in the FeatureTable, but it doesn't show as Selected and it doesn't Highlight. I figured out that I can cheat by using featureTable.selectRows("0"), but it seems silly to do it this way since clearly it knows which feature I'm clicking when it filters it as the only feature in the table. I should also say that the Feature isn't actually added to the View, (as I am mostly using MapImageLayers for the actual visible Layers) but the Search widget seems to be able to use the non-visible FeatureLayer and highlight it, so I would assume the FeatureTable can too.
So my questions are:
1) Does the layer have to be visible to highlight?
2) What am I missing in regards to having it register as "selecting"?
3) Is there a way to have the FeatureTable not load data upon first loading? I only want to use the FeatureTable to show what the user is selecting, so I don't need a list of all 109k features to begin with.
Thank you as always!
