Hey guys,
I am teaching a class on python through arcpro. I understand that I am supposed to clone arc's environment through arcpro, but from a teaching perspective this is terrible since they wont understand how to use conda outside of arc.
I had previously been able to create a new working environment using:
conda create -n spatial arcpy arcgis -c esri
But now when I activate and go to import arcpy, I get a zanny error and the suggestion to do the very thing I would like to avoid.
The version of the binaries in the active Python environment do
not match the version of the binaries in the ArcGIS application.
Active environment version : 3.0
arcgispro-py3 environment version : 2.9
To update the existing environment see the conda proup subcommand
> conda proup --help
To manually create a new environment for use with the current ArcGIS application:
1. Generate a list of additional packages installed in your current environment,
with the conda command:
> conda env export > env.yaml
2. (Optional) If you have additional dependencies installed through pip,
find those with pip freeze:
> pip freeze > requirements.txt
3. Create a new environment by cloning arcgispro-py3, and activate it:
> conda create --clone arcgispro-py3 --name my-env --pinned
> activate my-env
4. Add back missing conda packages from your current environment:
> conda env update -n my-env -f env.yaml
5. (Optional) Add back missing packages from pip:
> pip install -r requirements.txt
6. (Optional) Make it the default for the ArcGIS application and the
"Python Command Prompt":
> proswap my-env
File "c:\Users\mmann\Dropbox\6308 v2\IGSUP-New\IGSUP_data\0_Running_scripts\Solution\BufferCorvallisSchools.py", line 1, in <module>
import arcpy
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 88, in <module>
from arcpy.geoprocessing import gp
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\__init__.py", line 14, in <module>
from ._base import *
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 14, in <module>
import arcgisscripting
File "C:\Users\mmann\Anaconda3\envs\spatial\lib\site-packages\arcgisscripting\__init__.py", line 115, in <module>
raise ImportError("version mis-match") from None
ImportError: version mis-match
Any ideas? Is the conda-feedstock broken?
