We're getting ready to migrate our environment from our Geodatabase on Sql Express 2012 (64 bit) to Sql Standard 2019 (on a new server). Currently in the process of creating the new SQL server and procuring the SQL Standard ESRI licenses. Looking for suggestions or any potential 'gotchas'.
Current Environment
SQL Express 2012 (64 bit) , ODBC 2012 connector on workstations, Arcmap 10.6, ArcPro 2.2.4, ArcGis License Manager 2021.0. Single geodatabase in SQL Instance named 'arcgis'.
New Environment
Sql Standard 2019 (new server name, but same SQL instance name of 'ARCGIS'), ODBC 2019 connector on workstations, Arcmap 10.8 (or newer), ArcPro 2.8 (or newer)
When I migrate the SQL Express geodatabase to SQL 2019, will our current Arcmap 10.6 and ArcPro 2.2.4 run if we upgrade the ODBC connector to 2019 on the workstations? Or do we need to upgrade Arcmap and ArcPro at the same time as the geodatabase migration? Would prefer to not upgrade Arcmap and arcpro at the same time as moving the geodatabase but not sure if that's even an option.
Being an IT guy and not an Arcgis guy, I read about having to update the MXD files post geodatabase migration. What specifically are the steps that our ArcGIS users will need to do for the MXD files or other steps post migration? Other Arcgis files that will need updating besides MXDs?
Any migration steps that have worked better than others (Detach/Attach vs Backup/Restore)?
Thanks in advance.
