Our goal is to clone pre-defined Survey123 templates. Our environment is ArcGIS Enterprise. Based on this tutorial: https://developers.arcgis.com/survey123/guide/clone-surveys-from-one-organization-to-another/ it was pretty straightforward to clone a single survey.
Things get more tricky if the SurveyForm references a WebMap item. Although we are able to clone the WebMap item, based on the tutorial from the link, the Survey123 Form still references the WebMap Item from the template and not the cloned one.
As a workaround we found out that we can download the Survey123 Form as a zip file, open the *.info json and update the displayInfo -> map -> defaultType -> name reference and reupload the zip (like described here: https://developers.arcgis.com/survey123/guide/update-contents-of-the-media-folder-for-an-arcgis-survey123-form-item/#Download-survey) - but this feels like a very, very hacky way of doing something that sounds like it should be done via some python API commands rather than doing a zip download/upload.
Is there any better way of doing this? Updating the reference to the WebMap is just one usecase - in the future our templates will have more complex things like additional JavaScript files, Media Content etc. It would be very frustrating to update our GP Tool / Script every time a new template is defined to check if we don't miss any edge-case for cloning a Survey123 template.
