Hi Folks,
I created two webmaps with some views for editing control. One webmap is used by the field crew to census trees. This webmap contains labels with 3 attributes:
$feature.TAG + " - " + $feature.SPP + " - " + $feature["DBH_DAP"]
I saved the original map AS another webmap, which is used by supervisors. To make their work easy, the label for the trees needs to have 6 fields concatenated:
+ " - " + $feature["DBH_DAP2022"] + " - " + $feature.CODES
+ " - " + $feature.CODES2022
When opening the Supervisors map, the labels are shown perfectly (see the attached image named Labels_Online.jpg) when in online mode. If we take the same map offline and the open it, the labels default to other labels (see the Labels_Offline.jpg).
Is the saved map using a default label for this layer? Why is not using the labels defined on the map? Is there a limit on the number of fields used to create a label?
Thanks!
Milton
