I am new to experience builder and javascript as a whole so please bear with me. I am creating a custom widget that will apply unique value symbols to a feature layer (set in the settings file of the widget) based on a given field. So far I have been able to access the feature layer on line 13 but I am unsure how to apply the symbology on the feature layer. On the returned feature layer's methods, I didn't see any method to set the renderer.
/** @jsx jsx */
import { React, AllWidgetProps, jsx, DataSourceComponent,
SqlQueryParams, DataSourceManager, QueriableDataSource,
DataSource } from "jimu-core";
import { JimuMapViewComponent, JimuMapView, FeatureLayerDataSource } from "jimu-arcgis";
import Point from "esri/geometry/Point";
import { Button } from 'jimu-ui'
export default class Widget extends React.PureComponent<AllWidgetProps<any>, any>
onButtonClicked = e => {
const datasrc=this.props.useDataSources[0]
const fl=DataSourceManager.getInstance().getDataSource(datasrc.dataSourceId) as FeatureLayerDataSource
//need to set a renderer to fl here
render() {
return <div className="widget-starter jimu-widget">
<DataSourceComponent
useDataSource={this.props.useDataSources[0]}
widgetId={this.props.id}
<Button onClick={this.onButtonClicked} size="default">
Button
</Button>
</div>;
@Jianxia @GavinRehkemper @milesleeaus @EmilieRabeau @SpatialNinja @TonghuiMing @jcarlson @KenBuja @RhettZufelt @ShengdiZhang @ZhifangWang @DaveFullerton @DavidMartinez
