Hello, I have a question. I try to name the polygons according to the location of the points in them. But some have two points with different names, and if they have one and one name, I would like to decide according to which polygon they have a border. This is not the whole problem, but the problem occurs when they have a boundary with more polygons. I would like to do this in such a way that I find the longest border with the second polygon. I know everything to do until it's time to compare the lines. I don't know how to store both the length of the line and its name in the list. Would anyone have advice?
Here is the code:
foreach (var oid in oids)//a list of polygons with multiple identical names by OID
QueryFilter qFil = new QueryFilter();
qFil.WhereClause = "OBJECTID =" + oid.ToString();
var polygonSearch = fcPlochy.Search(qFil);
while (polygonSearch.MoveNext())
var feature = polygonSearch.Current as Feature;
var geometry=feature.GetShape() as Polygon;
var polyline = new PolylineBuilder(geometry).ToGeometry();
var spatialQueryInter = new SpatialQueryFilter()
FilterGeometry = geometry,
SpatialRelationship = SpatialRelationship.Touches,
TableDefinition tableDefinition1 = fcPlochy.GetDefinition();
var polyCursor4 = fcPlochy.Search(spatialQueryInter);
int namePolygons = tableDefinition1.FindField(field);
while (polyCursor4.MoveNext())//this is how it works for one adjacent polygon
var newFeature = polyCursor4.Current as Feature;
var newGeometry = newFeature.GetShape() as Polygon;
var polylineNew = new PolylineBuilder(newGeometry).ToGeometry();
Row row2 = polyCursor4.Current;
Geometry g = GeometryEngine.Instance.Intersection(polyline, polylineNew);
Polyline result = g as Polyline;
lineLength.Add(result);
string namePolygon = row2.GetOriginalValue(namePolygons) as String;
feature[newRow] = namePolygon;
feature.Store();
Thank you
David
