I had been using ArcGIS Pro 2.8 with this workflow to georeference images and share them with my organization.
Process to Georeference plan sheets:
1Download plans pdf
2Open in bluebeam
3Extract the single page you want to georeference
4 save the page as tif
5Add that tif to arcgis pro
6The arcgis pro map should be set to use the KRCS Zone 11 county system projection
7In arcgis pro change the appearance to grayscale stretch from rgb classified (if not in color)
8Give the appearance some transparency, around 33%
9Arcgis pro - imagery - georeference
10Zoom to project location, rotate, zoom, and fit to display until lot corners are very close, within about 5 ft
10.5 change layer order so image is under plats/parcels
11Place a few control points to tie the lot corners down
If it gets weird remove the tif and go back to step 5
12Save the control points
13Save the image in the georef toolbar
14Copy the image to another map for publishing to arcgis online in the web mercator projection
15Publish the tiled image service
Share - web layer - tile
Folder - plan review; share with city;
Configure - AGS/web maps, Cache locally to save credits
Analyze, ignore web mercator warning
Publish at an the most detailed tile scale with a size that is around 4-6 MB
16Add the image service to the map in KRCS projection and remove the tif
17Save the map
Short version, I was georeferencing in the project coordinate system, then once that image was georeferenced I could publish in web mercator tiles by copying the georeferenced image (Saved) into the web mercator projection map. Now I am using ArcGIS Pro version 2.9 and this workflow results in an unknown spatial reference for the georeferenced image, unless I temporarily save the georeferenced image as a new image.
Has anybody else noticed this difference? It adds a step I would prefer not to add into my workflow. Was this an intended change or is it a bug with copying a georeferenced file between maps? Even if I import control points to the image Pro will not recognize the spatial reference when attempting to publish in the web mercator projection unless the georeferenced image has been saved as a new image - I think this is a bug, I prefer the previous behavior.
