Hello everyone,
I have seen several posts on burning across digital dams on a DEM (roads and the like). I have tried several of the proposed solutions to no avail. In the end I want to delineate a stream network using Fill>Flow Direction>Flow Accumulation without erroneous routes along roads. I don't have culvert database or anything so I created a shapefile and drew the lines across the digital dams. I created a field in the shapefile with an elevation attribute and entered the downstream elevation at the end of each line. I know I can convert this to a raster. I just need to figure out how to use these lines, in shapefile or raster form, to burn through the digital dams and have a final DEM that I can use for my stream network. I am using Arc Pro.
Thanks!
