I published a layer for Field Maps on our internal GIS portal (10.8.1) that consists of a point feature class and a related table. Some of fields in both use domains. I collected test data then downloaded the results as both a file geodatabase and as an Excel workbook. I need it in table format like Excel in order create paper output of the attributes.
Looking at the tables in the exported geodatabase in Pro, I see the descriptions in the domain-controlled fields. In the Excel export, those fields also show the description in the features attribute table, but the related table has the codes. Why are they different? One works and the other doesn't?
Bug? Suggestions?
