I have various polygon datasets that I need to split by lines (separate datasets). I was using ArcMap (find the same process in ArcGIS Pro as heavy process and slower), in that by editing the polygon, selecting the lines and us the Cut Polygons tool on the Editor toolbar.
The process works, however, i as some datasets that cannot be split and getting in return an error failing to split the polygons. I ran the repair geometry for the polygons, however, this did not resolve the issue.
What do you think the problem might be?
On another note, do you have another option how to split a polygon by a line apart from the method described above?
Thanks a lot
Frank
