Hi!
I am trying to use the SearchCursor on a featureclass that is in a dataset that I access with an SDE - but I can't get it to work.
I have following structure in the SDE-server:
I want to access sde_geopipe.pipeWaterPipe with SearchCursor - I have the following code:
arcpy.env.workspace = './data/AD@sde_geopipe_uva.sde'
with arcpy.da.SearchCursor('sde_geopipe.Water/sde_geopipe.pipeWaterPipe', field) as cursor:
for row in cursor:
print(row[1])
I also tried to specify the full path ('./data/AD@sde_geopipe_uva.sde/sde_geopipe_uva.GNG.Vatten/sde_geopipe_uva.GNG.pipeWaterPipe') but that didn't work.
