I am trying to use arcpy to loop through 20 or so feature classes, select by attribute certain rows and export to a new feature class. The field names are all different, so I want to identify if these words exist in ANY of the fields in the entire attribute table. Below is my script, but I keep getting hung up on: TypeError: argument of type 'int' is not iterable.
Help!
import arcpy
import os
import sys
import arcpy
from arcpy import env
from arcpy.sa import Con
from arcpy.sa import *
inworkspace = r'F:\St Kateri Conservation Center\GIS\Ohio\Ohio_parcels_prj_2.gdb'
outworkspace_c = r'F:\St Kateri Conservation Center\GIS\Ohio\Ohio_C_Parcels.gdb'
outworkspace_results = r'F:\St Kateri Conservation Center\GIS\RESULTS\Ohio_Results.gdb'
#set the environment
arcpy.env.workspace = inworkspace
parcels = arcpy.ListFeatureClasses()
print(parcels)
for fc in parcels:
infc = fc
outname = "c_" + fc
outfc = os.path.join(outworkspace_c, outname)
arcpy.CopyFeatures_management(infc, outfc)
arcpy.DeleteFeatures_management(outfc)
curT=arcpy.da.InsertCursor(outfc,"*")
with arcpy.da.SearchCursor(infc,"*") as cursor:
for row in cursor:
if any(['Cat' in substring for substring in row]):
curT.insertRow(row)
elif any(['St' in substring for substring in row]):
curT.insertRow(row)
elif any(['CAT' in substring for substring in row]):
curT.insertRow(row)
elif any(['Sisters' in substring for substring in row]):
curT.insertRow(row)
elif any(['Saint' in substring for substring in row]):
curT.insertRow(row)
