I have started looking into the Pivot Table gp tool in Arcgis Pro and I am not satisfied with its performance... but it also might be that I am missing some essential clue on best practice. The following is an example of input:
When doing pivot in excel I end up with something like this (ignoring material):
But doing the same in Arcgis i get something like this:
I understand the reason (I think); it summarizes per material per coordinate, even though I only put coordinate as an input field. I have tested this with adding material and get the same output. Only difference is that it adds a column for material.
Is this how it is supposed to work or is it bugged? If it is how it should work then I must say it does not do a good job...
