It would really be helpful to be able to change the symbol for the point that is placed at the center of the map when the Search widget is used with a locator, for example, to zoom to an address and show the point on the map. As you can see below, the yellow dot is not very visible against all basemaps. If possible, we would like to be able to make composite symbols (e.g., crosshair reticle - circle with no fill surrounding a plus sign).
