I am building a Python script for a client who wants a bunch of hosted feature services exported to file geodatabases. The script I've written works just fine. Each hosted feature service is exported to a GDB then downloaded to a location of my choosing.
The issue is that each unzipped GDB has a seemingly random name. For example:
'Test_Layer_1.zip' once unzipped turns into '_ags_dataD621677BB64F4D2D98CD0D1B1CF805BD.gdb'.
Is there a way to set the name of the GDB as a parameter?
Here is what I've worked out so far...
## Import modules
import os
import datetime
from arcgis.gis import GIS
import zipfile
# Create destination folder
today = datetime.datetime.now()
path = 'C:/workspace/pythontest' + today.strftime('%m%d%Y')
os.mkdir(path)
dest = path
extension = ".zip"
# Define variables for GIS
PortalUrl = 'https://redacted.redacted.local/portal'
PortalUserName = 'username'
PortalPassword = 'password'
gis = GIS(PortalUrl, PortalUserName, PortalPassword)
# Define input layers
# itemid1 = 'c9325f2f3d7b430b93047230bbe004ac' = 'Test_Layer_1'
# itemid2 = 'edfe40f03dee40839a92ee2bd695cf62' = 'Test_Layer_2'
# Export Test_Layer_1
dataitem1 = gis.content.get(itemid1)
dataitem1.export('Test_Layer_1', 'File Geodatabase', parameters=None, wait=True)
myexport1 = gis.content.search('Test_Layer_1', item_type='File Geodatabase')
fgdb1 = gis.content.get(myexport1[0].itemid)
fgdb1.download(save_path=dest, file_name='Test_Layer_1' + ".zip")
fgdb1.delete()
# Export Test_Layer_2
dataitem2 = gis.content.get(itemid2)
dataitem2.export('Test_Layer_2', 'File Geodatabase', parameters=None, wait=True)
myexport2 = gis.content.search('Test_Layer_2', item_type='File Geodatabase')
fgdb2 = gis.content.get(myexport2[0].itemid)
fgdb2.download(save_path=dest, file_name='Test_Layer_2' + ".zip")
fgdb2.delete()
# Unzip ZIP files then delete the ZIP files
os.chdir(dest) # change directory from working dir to dir with files
for item in os.listdir(dest): # loop through items in dir
if item.endswith(extension): # check for ".zip" extension
file_name = os.path.abspath(item) # get full path of files
zip_ref = zipfile.ZipFile(file_name) # create zipfile object
zip_ref.extractall(dest) # extract file to dir
zip_ref.close() # close file
os.remove(file_name) # delete zipped file
