I'm upgrading a model that processes GPS Points. From the GPS device we can only get a table with every point, so I'm trying to create additional function that will go to the ultimate GDB and get the last date in the field "Start_Time" which is a date field. I achieve this by sorting by descending of this field and then "Get Field Value" from utilities into a date variable. Where I'm stuck is making the SQL expression using inline replacement to delete all the values that are lower than the variable I got from the server. However everything I've tried returns an error saying the expression is invalid.
Expressions I've tried based off this article:
Start_Time >= date %Last_Start_Date%
"Start_Time" >= date %Last_Start_Date%
Start_Time >= %Last_Start_Date%
"Start_Time" >= %Last_Start_Date%
Start_Time >= /'%Last_Start_Date%/'
The value that the variable reports is:
2/12/2021 5:00:41 AM
I don't really know what else to try. Its really hard to understand why it doesn't work when the error just says it doesn't work.
