We added an on screen widget and made the button invisible per client request; they want it to open from somewhere else. Client has 2 sets of layers they want showing, in separate layer lists/table of contents (TOC) widgets. We got that working, basically by adding a second widget and configuring it to the second set of layers.
We added a button to the bottom of the second TOC widget.
So right now you can click the first TOC widget icon, see its layers listed, then click the second TOC widget icon, and it's layers also get listed, but it has a 'launch report' button at the bottom which launches our custom widget. The problem is once you click that button, after succesfully launching the custom widget, it closes the 2nd TOC list and switches back to the 1st TOC widget, since they shared the same panel.
How we made the button work:
1) added code to the 2nd TOC's html file
<a style="float:left; margin-right:10px; font-weight: bold; font-size: large;" href="#" data-dojo-attach-point="btnLaunchReport">Launch Report</a>
2) added code to the TOC's widget.js file
//under bindEvents
this.own(on(this.btnLaunchReport,
'click',
lang.hitch(this, this._reportWidget)));
//new function
_reportWidget: function() {
var widgetCfg = this._getWidgetConfig('reportWidget');
widgetCfg.visible = true;
var headerCfg = this._getWidgetConfig('HeaderController');
var headerWidget = this.widgetManager.getWidgetByLabel(headerCfg.label);
//This is need to show the widgets icon in the header
headerWidget.resize();
//This actually open the widget
headerWidget.setOpenedIds([widgetCfg.id]);
console.log(widgetCfg.id);
this initially gave us errors saying that the config object was missing so we added code (lines 10-12, and 15) to the header controller widget.js below.
//this is in themes/FoldableTheme/widgets/HeaderController
//we tweaked the original setOpenedIds function to look for our widget's config if it gets here and cant find one
setOpenedIds: function(ids) {
console.log("This is the ID test " + ids);
if (ids.length === 0) {
return;
var config = this.getConfigById(ids[0]);
if(ids[0] == "_49"){ // set to our widget ID number
config = this._getWidgetConfig('reportWidget');
if (!config) {
console.log("No config found for " + ids[0]);
return;
if(this.openedId){
this._switchNodeToClose(this.openedId);
this.openedId = ids[0];
if (config.widgets && config.openType === 'openAll') {
this._switchNodeToOpen(config.id);
} else if (!config.widgets) {
if(this._getIconNodeById(config.id)){
}else{
this._showIconContent(config);
},It worked, successfully launching the custom widget, but side effect is it closes the TOC widget which shows all the layers, so the user would have to open it again. Minor bug but still a bug. It also launches an error in the console "TypeError:can't access property "className", b is null in the _showIconContent line, which implies that the code is hitting the header controller widget again after launching the custom report widget. So I'm not sure what's going on there.
I'm sure we're doing it wrong. Any help would be appreciated.
