In this session we tried to cover the variety of ways to enter measurements in ArcGIS Pro:
1. What is “COGO Enabled”? why did we switch from using text fields to double field type? Field formatting and display expressions.
2. Using ‘Show Only Active Record’ while entering data
3. Editing Constraints, dynamic constraints, COGO aware tools...
4. Traverse:
a. Open and close traverse
b. New traverse
c. Shortcuts: quadrant bearing, tangency, chord and radial bearings, delta angle…
d. Built-in calculator
e. Setting closure tolerance
f. Area and misclose ratio
g. Traverse with missing information
h. Help documentation
i. Picking up from where you've left using trace
j. Entering a natural boundary
k. Adjustment methods
l. Import/export ArcMap Traverse TXT file
m. What’s new in 2.9? propagation of tangency
n. Upgrading COGO values from ArcMap to ArcGIS Pro
5. Editing tips and tricks: feature template overrides, entering measurements in other editing tools
6. Ground to Grid correction
7. Where did this COGO come from? The COGO Type
8. Partial measurements
9. Lines with no measurements
