could anyone tell me just looking at the code where could there be a bug? The original code that I managed was functional, but I wanted to simplify the code even more, and it no longer works.
protected override async void OnClick()
FeatureLayer fl = MapView.Active.Map.FindLayers("O_Klad_ZTM10").First() as FeatureLayer;
if (fl == null)
return;
await QueuedTask.Run(() =>
QueryFilter qf = new QueryFilter();
string whereClause = "ZTM10_nom LIKE '0602%'";
qf.WhereClause = whereClause;
fl.Select(qf);
var path = @"D:\PomocnaVrstva.shp";
var extent = 200;
// CalculateBuffer(fl, path, extent, "Meters");
object[] listParameter = {fl, path, extent, "Meters"};
await StartGp("analysis.Buffer", listParameter);
int indexNumber = 0;
var mapView = MapView.Active;
if (mapView != null)
Uri shpUri = new Uri(path);
await QueuedTask.Run(async ()=>//from here it no longer takes place
Layer shapeLayer = LayerFactory.Instance.CreateLayer(
shpUri, mapView.Map, indexNumber, "PomocnaVrstva");
// var selectedLayer = mapView.GetSelectedLayers()[0] as FeatureLayer; není potřeba
var shpLayer = shapeLayer as FeatureLayer;
var pathDis = @"D:\DissolvePomocnaVrstva";
//// DissolveLayer(shpLayer, pathDis);
object[] listOfPara = {shpLayer, pathDis};
await StartGp("management.Dissolve", listOfPara);
FeatureLayer dissFeat = MapView.Active.Map.FindLayers("DissolvePomocnaVrstva").First() as FeatureLayer;
var overlapType = "COMPLETELY_WITHIN";
var selectionType = "NEW_SELECTION";
var pathErase = @"D:\ErasePomocnaVrstva";
//SelectLayer(featLayer, overlapType, dissFeat, selectionType);
FeatureLayer featLayer = MapView.Active.Map.FindLayers("O_Klad_ZTM50").First() as FeatureLayer;
object[] listOfParameter = { featLayer, overlapType, dissFeat, selectionType };
await StartGp("management.SelectLayerByLocation", listOfParameter);
//EraseLayer(dissFeat, featLayer, pathErase);
object[] parameterList = { dissFeat, featLayer, pathErase };
await StartGp("analysis.Erase", parameterList);
private static async Task StartGp(string funcArc, object parame)
var parameters = Geoprocessing.MakeValueArray(parame);
FunctionPart(funcArc, parameters);
//private static void CalculateBuffer(FeatureLayer featureLayer, string sOutputPath, double dDistance, string sUnits)
// var parameters = Geoprocessing.MakeValueArray(featureLayer, sOutputPath,
// string.Format(CultureInfo.InvariantCulture, "{0} {1}", dDistance, sUnits));
// var buffer = "analysis.Buffer";
// FunctionPart(buffer, parameters);
//private static void DissolveLayer(FeatureLayer featureLayer, string sOutputPath)
// var parameters = Geoprocessing.MakeValueArray(featureLayer, sOutputPath);
// var dissolve = "management.Dissolve";
// FunctionPart(dissolve, parameters);
//private static void EraseLayer(FeatureLayer featureLayer, FeatureLayer eraseFeatureLayer, string sOutputPath)
// var parameters = Geoprocessing.MakeValueArray(featureLayer, eraseFeatureLayer, sOutputPath);
// var erase = "analysis.Erase";
// FunctionPart(erase, parameters);
//private static void SelectLayer(FeatureLayer featureLayer, string overlapType, FeatureLayer selectFeature, string selectionType)
// var parameters = Geoprocessing.MakeValueArray(featureLayer, overlapType, selectFeature, selectionType);
// var selectLayer = "management.SelectLayerByLocation";
// FunctionPart(selectLayer, parameters);
private static async Task FunctionPart(string stringFunc, IReadOnlyList<string> parameters)
try
await Geoprocessing.ExecuteToolAsync(stringFunc, parameters).ConfigureAwait(false);
catch (Exception ex)
Debug.WriteLine(ex.ToString(), Assembly.GetExecutingAssembly().FullName);
throw;
I will be very grateful for every idea.
Thank you!
