I'm trying to display the grid label (coordinates) of a MapFrame on the right side of the map, but can't figure out how to do this. At the moment they are on the left side. I'ld like to do this in my code...
I've found the indices for position on the element:
Grid position indexes. Coordinates on the left side (I want them on the right side)
And my code:
var gridLabelsNorthSouth = new CIMGridLine
Name = "Labels",
ElementType = GridElementType.Label,
GridLineOrientation = GridLineOrientation.NorthSouth,
Pattern = new CIMGridPattern { Interval = this.printOptions.KoordinatenGitter, Start = 1, Stop = 0, Gap = 0 },
VisibleIndices = new int[] { 3, 4 }, // <-- This is not working
FromTick = new CIMExteriorTick
Length = 0.0694,
Offset = 0,
IsVisible = true,
EdgeAffinity = new int[] { 3, 4 }, // <-- This is not working
GridEndpoint = new CIMGridEndpoint
GridLabelTemplate = new CIMSimpleGridLabelTemplate
// DynamicStringTemplate = $"<dyn type=\"grid\" units=\"{gridUnits}\" decimalPlaces=\"0\" separator=\"True\" showDirections=\"False\" showZeroMinutes=\"False\" showZeroSeconds=\"False\"/>",
DynamicStringTemplate = $"<dyn type=\"grid\" decimalPlaces=\"0\" separator=\"True\" showDirections=\"False\" showZeroMinutes=\"False\" showZeroSeconds=\"False\"/>",
Symbol = (SymbolFactory.Instance.ConstructTextSymbol(ColorFactory.Instance.BlackRGB, 8, "Arial", "Regular")).MakeSymbolReference()
Offset = 0.083,
Position = 4, // <-- This is not working
LineSelection = 7
ToTick = new CIMExteriorTick
Length = 0.0694,
Offset = 0,
IsVisible = true,
DynamicStringTemplate = "", //TODO
Symbol = (SymbolFactory.Instance.ConstructTextSymbol(ColorFactory.Instance.BlackRGB, 0.5, "Arial", "Regular")).MakeSymbolReference()
Offset = 0.083,
LineSelection = 7
var projectedCoordinateSystem = mapframe.Map.SpatialReference.ToCIMSpatialReference() as ProjectedCoordinateSystem;
CIMMapGrid mapGrid = new CIMMeasuredGrid
Name = "GEODAT-Tools_MapGrid",
GridLines = new CIMGridLine[] { gridLinesEastWest, gridLinesNorthSouth, gridLabelsEastWest, gridLabelsNorthSouth },
IsVisible = true,
ProjectedCoordinateSystem = projectedCoordinateSystem,
var mapFrameDefinition = mapframe.GetDefinition();
CIMMapFrame cimMapFrame = mapFrameDefinition as CIMMapFrame;
cimMapFrame.Grids = new CIMMapGrid[] { mapGrid };
mapframe.SetDefinition(mapFrameDefinition);
Any advice ?
Thanks !
