We recently switched over to ArcGIS Pro 2.8 from ArcMap 10.6.1. I am trying to get a project set up for daily usage and I'm encountering many things that were once easy, take a lot of setting up
Current conversion problem:
In ArcMap we would have a layout setup that we would simply have to switch to after completing the work in map view. With Pro, the layout view locks the map extent once it is created. Since we do parcel editing, we create before and after views of what we worked on to be sent to other departments. Once one parcel is done, we move on to the next. It seems like in Pro the map frame will have to be adjusted separately from the map view every time a new area is worked and a map is needed. In ArcMap it was simple; whatever was showing in map view where the edits were done was the same area displayed in the layout view to print the map.
Is there a way to synch the map frame within the layout view to automatically display the current extent in the map view?
