I use ArcGIS Pro and the rest of my team uses ArcMap. I sometimes get assignments that require me to import map documents to work with the same template my team has used in the past.
A more recent development is that ArcGIS Pro crashes immediately when I try and import a map document file. I've done this in the past, but it does not work now. I am using the latest version (2.8.1).
Curiously and probably related, I cannot open ArcMap 10.8 on my computer anymore either. I guess these two are related and welcome suggestions. The error report for this has been sent, but error reports for ArcGIS Pro fail more often than not.
Thank you.
