I'm trying to switch from using the os module to pathlib.Path for working with file paths. For some reason, when I construct the path to the feature class (or table) with Path, it fails with
RuntimeError: 'in_table' is not a table or a featureclass
If I simply convert the path to string in the cursor using str(), it works fine. A print() of the path looks normal; not a weird object or something. I get the same behavior with a file geodatabase and Oracle 12c enterprise geodatabase. I also tried using Path.joinpath() instead of the shorthand / but had the same error.
Is there a different way I should be constructing paths?
from pathlib import Path
egdb_conn = r"C:\GISConnections\user@instance.sde"
fc_path = Path(egdb_conn) / "schema.tablename"
print(fc_path)
print(arcpy.Exists(fc_path))
with arcpy.da.SearchCursor(fc_path, ["OID@"]) as search_cursor:
for row in search_cursor:
print(row)
BTW, I'm on ArcGIS Pro 2.8
