I'm creating a smart form in the Field Maps web application, and I'm running into the issue when I click on my template in the editable layers, no attributes show up under the default values pane on the right hand side. I created this template in ArcGIS Pro (this is where I set whether a field is nullable, the defaults, domains, etc), and published it as a hosted feature layer in AGO. The domains and defaults can be seen when I click on the "data" tab on the feature layers page, but for some reason they are not showing up in Field Maps.
