I have a geodatabase feature class that I'm trying to uploaded to ArcGIS Online, either directly through ArcMap or by uploading the geodatabase. In each case the feature class uploads successfully; however, in each case the feature class is empty.
I have another feature class which is very similar that is uploading successfully. Here's the stats for both:
Number of records: 47 (successful FC), 48 (unsuccessful FC)
Projection: WGS_1984_Web_Mercator_Auxiliary_Sphere
Contents: Simple polylines, no Z values, no measures
Field names: Successful FC (OBJECTID, Shape, map, name, type, am, mid, pm, eve, Legend_name, Shape_Length)
Unsuccessful FC (OBJECTID, Shape, LineAbbr,Legend_name,ROUTE_NAME,Shape_Length)
-- map, name, Legend_name, LineAbbr, ROUTE_NAME are all strings; most of the rest are short integers except for the geometry ones
I've uploaded dozens of feature classes to ArcGIS Online and never had a problem. I have no idea what's going on here. This is a simple and straightforward feature class which displays just fine in ArcMap (10.2.1). Any thoughts? Thanks.
- geoff
