I have two options for mobile data collection: Field Maps and Survey 123. In Field Maps, I can create geometries that remain visible on the display. However, so far I have not found a way to select multiple attributes for a geometry (point, etc.) (e.g. plant species list at a site). In Survey 123, I can select multiple attributes for one geometry using the handy 'multi_select' field type. However, the geometry created does not remain visible on the display after capture. So my question: is there a way to create a feature with a field type similar to 'select_multiple' as in Survey123 for use in Field Maps? Or is there a way to make the already collected points visible in Survey 123 (without revisiting the records in the output)? I have little experience yet and ask for your indulgence. Thanks already for all helpful answers.
Thomas
