I'm trying to create a map series where the extent of each map is based on features other than the series' index layer. E.g., index feature 1 is within feature A, and I need the map extent to cover the entirety of feature A. Index feature 2 is within feature B, etc. The problem is map series extent isn't designed for such a scenario. I'm trying to brainstorm a workaround. I could use features A, B... as the index layer, but then I'm not sure how I'd create a page query to get the corresponding feature 1, 2... There is not a 1-to-1 ratio of features A, B to 1, 2. Feature A might contain features 1, 2, 3, 4 and I need a map page for each feature 1, 2, 3, 4. Plus, there are dynamic text elements in the layout driven by features 1,2..., so that really wouldn't work.
It's probably possible to do this with Python, but I'm not entirely sure how. I'm thinking it would be a For loop, looking for the index features (1, 2, 3) and an attribute of each feature would be used use to select the corresponding feature A, B, C. Could also use a spatial selection. Has anyone else attempted something similar? Would this even be handled like a map series in Python? I'm thinking probably not. Should this be an idea suggestion for a future version of map series in Pro? Thanks for reading my ramble!
