Currently the Explore Tool is set as the default in Pro Parcel Fabric. Once you make a selection with the Select Tool and for example, edit vertices of a line, the selection goes back to the Explore Tool. It would be more efficient if your current selection stayed active (either Explore or Select). In this example I would be selecting different lines or polygons to edit and having to constantly go back and select the Select Tool isn't very time efficient which is what Pro Parcel Fabric is all about.
