What's fastest way to convert the dictionary below of polygon features into an in_memory feature class?
<SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"COUNTIES"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"COUNTY"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"COUNTY 1"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"COUNTYRINGFEATURE"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"rings"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8930981.5967</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3040606.1534</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8930880.296</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3040593.7322000004</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8930860.2585</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3040604.911200002</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8930361.547</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3040438.4703</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8929910.703</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3040288.178100001</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8929241.6727</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3040065.848200001</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8928384.5124</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3039780.1779000014</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8928253.1552</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3039740.4329000004</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"COUNTYOID"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">50</SPAN>
<SPAN class="string token">"COUNTY"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"COUNTY 2"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8947371.1721</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118264.7214</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8947243.1547</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118263.4723999985</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8946191.1852</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118252.2322999984</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8946173.3741</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8946160.0158</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118250.9833999984</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8946099.9032</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8945873.9246</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118249.7346</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8945723.6431</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118244.7388000004</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8945527.7209</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8945303.9686</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118242.2410999984</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8945138.1025</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118238.4943999983</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8945100.2539</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8941077.1663</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118199.7786</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="number token">8937553.9034</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">3118162.3117000014</SPAN>
<SPAN class="string token">"COUNTYOID"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">61</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
