Hi All,
I've gotten over my hurtle with creating attribute rules now, but I'm a newbie with Arcade - either in the WAB or in Pro.
I'm attempting to create a Calculation rule that is based on If Then Else statements. I am getting a message about Invalid expression. Error on line 8. Open parenthesis expected.
Here's the beginning of my expression; at the end I do have return eru; As this is the field that I am attempting to calculate. There will be three of these set up so as to do the required pre-calcs before getting the last two calculations that are the real ones to be returned and saved.
It is highly likely that I'm missing just something simple, I thought that I was following the examples that I found for doing calcs and using if statements. But ....
var fs = FeatureSetByName($datastore,"IDF_Stormwater");
var billclass = fs["MultiUserType"];
var eru = fs["ERUArea"];
var parea = fs["IDFArea"];
var pimparea = fs["ImperviousArea"];
var dwell = fs["Dwellings"];
if billclass == 'D'
eru = 0
else if billclass in ('V','I','H')
eru = Round(parea/43560,2)
else if billclass == 'R'
eru = Round(parea*(2000/7760)/2000,2)
else if billclass in ('A','O')
Lorinda
