I am writing to ask if others have experienced the map in Field Maps freezing up to the point you can't click or move. On the screen it shows a wheel spinning as if its trying to do something.
I assist others with using these apps and today as someone was preparing to fly an aerial survey the map froze up. When they powered down and reopened the app the map was again responsive. This has been also reported by four other users all using separate and brand new iPad Pros. The users have downloaded pre-defined map areas and I'm trying to have them take note when this happens what they were doing. Luckily it has been pretty sporadic, but still for aerial surveys this is troubling. If surveyors had collected data and the map/app froze up and they powered down will these lose local edits?
Thanks in advance,
Kathy
