I am having problems lining up Absolute XY coordinates in ArcGIS Pro 2.0.1. I am able to run Locate XY and even Make XY Event Layer successfully in ArcGIS Pro, but entering Absolute XY while editing drops the point in the wrong location.
See attached screenshots for comparison with the exact same process and settings in ArcMap10.5.1, which works. This is a common tool I use to map points and start Traverses by XY Point of Beginning. I've looked over my map properties, coordinate system settings, and edit settings but I can't figure out why this is happening.
