Hello everyone-
I am attempting to write my first real notebook based off a python script I wrote a while back. This script takes two layers, a "facility" layer, and a county layer, joins them by facility name, adds and calculates today's date, then appends the data to another AGOL feature layer as an archive layer. I added a date field to the facilities, so no need to add a field via code anymore. However, I am having some issues with the field calculate function in Notebooks. From my understanding, it is a connection issue, but the rest of my code works fine. I frankly have no idea where to go from here to troubleshoot. My best guess is it's throwing the error because I didn't import the field calculate tool, but if that's the case I'm still lost. Thanks in advance!!
Imports:
from pathlib import Path
import sys
from arcgis.gis import GIS, Item
from arcgis.features import FeatureLayerCollection
from arcgis.features.analysis import join_features
import datetime
from arcgis.geoanalytics.manage_data import calculate_fields
Field Calc:
layer=joinData.id
dateCalc = calculate_fields(input_layer=layer,
field_name="data_date",
data_type="Date",
expression="datetime.datetime.now()")
Output:
gaierror Traceback (most recent call last)
/opt/conda/lib/python3.6/site-packages/urllib3/connection.py in _new_conn(self)
156 conn = connection.create_connection(
--> 157 (self._dns_host, self.port), self.timeout, **extra_kw
158 )
/opt/conda/lib/python3.6/site-packages/urllib3/util/connection.py in create_connection(address, timeout, source_address, socket_options)
60
---> 61 for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
62 af, socktype, proto, canonname, sa = res
/opt/conda/lib/python3.6/socket.py in getaddrinfo(host, port, family, type, proto, flags)
744 addrlist = []
--> 745 for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
746 af, socktype, proto, canonname, sa = res
gaierror: [Errno -2] Name or service not known
During handling of the above exception, another exception occurred:
NewConnectionError Traceback (most recent call last)
/opt/conda/lib/python3.6/site-packages/urllib3/connectionpool.py in urlopen(self, method, url, body, headers, retries, redirect, assert_same_host, timeout, pool_timeout, release_conn, chunked, body_pos, **response_kw)
671 headers=headers,
--> 672 chunked=chunked,
673 )
/opt/conda/lib/python3.6/site-packages/urllib3/connectionpool.py in _make_request(self, conn, method, url, timeout, chunked, **httplib_request_kw)
375 try:
--> 376 self._validate_conn(conn)
377 except (SocketTimeout, BaseSSLError) as e:
/opt/conda/lib/python3.6/site-packages/urllib3/connectionpool.py in _validate_conn(self, conn)
993 if not getattr(conn, "sock", None): # AppEngine might not have `.sock`
--> 994 conn.connect()
995
/opt/conda/lib/python3.6/site-packages/urllib3/connection.py in connect(self)
299 # Add certificate verification
--> 300 conn = self._new_conn()
301 hostname = self.host
168 raise NewConnectionError(
--> 169 self, "Failed to establish a new connection: %s" % e
170 )
NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f6b22926630>: Failed to establish a new connection: [Errno -2] Name or service not known
MaxRetryError Traceback (most recent call last)
/opt/conda/lib/python3.6/site-packages/requests/adapters.py in send(self, request, stream, timeout, verify, cert, proxies)
448 retries=self.max_retries,
--> 449 timeout=timeout
450 )
719 retries = retries.increment(
--> 720 method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
721 )
/opt/conda/lib/python3.6/site-packages/urllib3/util/retry.py in increment(self, method, url, response, error, _pool, _stacktrace)
435 if new_retry.is_exhausted():
--> 436 raise MaxRetryError(_pool, url, error or ResponseError(cause))
437
MaxRetryError: HTTPSConnectionPool(host='geoanalytics.arcgis.com', port=443): Max retries exceeded with url: /arcgis/rest/services/GeoAnalyticsTools/GPServer/CalculateField/submitJob (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f6b22926630>: Failed to establish a new connection: [Errno -2] Name or service not known',))
/opt/conda/lib/python3.6/site-packages/arcgis/gis/_impl/_con/_connection.py in post(self, path, params, files, **kwargs)
676 cert=cert,
--> 677 files=files) 678 except requests.exceptions.SSLError as err:
/opt/conda/lib/python3.6/site-packages/requests/sessions.py in post(self, url, data, json, **kwargs)
577
--> 578 return self.request('POST', url, data=data, json=json, **kwargs)
579
/opt/conda/lib/python3.6/site-packages/requests/sessions.py in request(self, method, url, params, data, headers, cookies, files, auth, timeout, allow_redirects, proxies, hooks, stream, verify, cert, json)
529 send_kwargs.update(settings)
--> 530 resp = self.send(prep, **send_kwargs)
531
/opt/conda/lib/python3.6/site-packages/requests/sessions.py in send(self, request, **kwargs)
642 # Send the request
--> 643 r = adapter.send(request, **kwargs)
644
515
--> 516 raise ConnectionError(e, request=request)
517
ConnectionError: HTTPSConnectionPool(host='geoanalytics.arcgis.com', port=443): Max retries exceeded with url: /arcgis/rest/services/GeoAnalyticsTools/GPServer/CalculateField/submitJob (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f6b22926630>: Failed to establish a new connection: [Errno -2] Name or service not known',))
<ipython-input-14-2e9a8f03d77d> in <module>
2 field_name="data_date",
3 data_type="Date",
----> 4 expression="datetime.datetime.now()")
/opt/conda/lib/python3.6/site-packages/arcgis/geoanalytics/manage_data.py in calculate_fields(input_layer, field_name, data_type, expression, track_aware, track_fields, time_boundary_split, time_split_unit, time_reference, output_name, gis, context, future)
974 gpjob = _execute_gp_tool(gis, tool_name, params, param_db, return_values, _use_async, url, True, future=future)
975 return GAJob(gpjob=gpjob, return_service=output_service)
--> 976 _execute_gp_tool(gis, tool_name, params, param_db, return_values, _use_async, url, True, future=future)
977 return output_service
978 except:
/opt/conda/lib/python3.6/site-packages/arcgis/geoprocessing/_support.py in _execute_gp_tool(gis, task_name, params, param_db, return_values, use_async, url, webtool, add_token, return_messages, future)
388 job_info = gptool._con.post(submit_url, gp_params)
389 else:
--> 390 job_info = gptool._con.post(submit_url, gp_params)
391 job_id = job_info['jobId']
392 if future:
684 except requests.exceptions.ConnectionError as errCE:
685 raise requests.exceptions.ConnectionError(
--> 686 "A connection error has occurred: %s" % errCE) 687 except requests.exceptions.InvalidHeader as errIH:
688 raise requests.exceptions.InvalidHeader(
ConnectionError: A connection error has occurred: HTTPSConnectionPool(host='geoanalytics.arcgis.com', port=443): Max retries exceeded with url: /arcgis/rest/services/GeoAnalyticsTools/GPServer/CalculateField/submitJob (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f6b22926630>: Failed to establish a new connection: [Errno -2] Name or service not known',))
