Hey All,
I have one server which hosts the ArcGIS server the portal and 2 web adaptors
I have successfully registered one of the web adaptors with the server but I am getting error while trying to register the second web adaptor with the portal (the portal is installed correctly and working)
ESRI Arc + portal + web adaptors version 10.7.1
Windows 10 Etn 64bit (32GB Ram) + IIS + RSA SSL Certificate
when I try register it from the web - I can see the following error in event viewer:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 10/16/2019 1:29:02 PM
Event time (UTC): 10/16/2019 10:29:02 AM
Event ID: c5f92c7191744d9da5b015879f65d9c4
Event sequence: 21
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT/portal-1-132156890571466549
Trust level: Full
Application Virtual Path: /portal
Application Path: C:\inetpub\wwwroot\portal\
Machine name: GIS
Process information:
Process ID: 17096
Process name: w3wp.exe
Account name: IIS APPPOOL\ArcGISWebAdaptorAppPool v4.0
Exception information:
Exception type: NullReferenceException
Exception message: Object reference not set to an instance of an object.
at ESRI.ArcGIS.WebAdaptor.WebAdaptor.()
at ESRI.ArcGIS.WebAdaptor.WebAdaptor.Page_Load(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Request information:
Request URL: https://gis.xyz.com:443/portal/webadaptor/WebAdaptor.aspx
Request path: /portal/webadaptor/WebAdaptor.aspx
User host address: fe80::897c:ba2:e15:c0cIIS APPPOOL\ArcGISWebAdaptorAppPool v4.0
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\ArcGISWebAdaptorAppPool v4.0
Thread information:
Thread ID: 50
Is impersonating: False
Stack trace: at ESRI.ArcGIS.WebAdaptor.WebAdaptor.()
Custom event details:
When I trying to register the web adaptor from command line I am getting the error:
Configuring Web adaptor...
Successfully Registered.
but it is not registered
Please help
Roy
