Not sure where to post this, so here goes.
For the past year or two (?), ArcMap and ArcCatalog, ArcMap more so, has left processes hanging in our PCs/Laptops.
This is where you go to Task Manager after you have closed out all your sessions, and see multiple ArcMap processes still showing.
1. This causes geodatabase locks
2. It shows as connections in ArcSDE
I read that this had to do with an extension or some connection ArcMap still thinks it is connected to. But asking our users to go to Task Manager to manually end these tasks is getting a little annoying.
Anybody face the same? Any ideas? We are on Windows 10 Enterprise & ArcGIS 10.7.1. We use the Pictometry (Connect) and the Streetview extensions in ArcMap most commonly.
This does not appear to be an issue with Pro (same commonly used extensions).
