Hey,
I have a question. I have gotten my line meta data reduced down to just the fields they requested. I am finished with most of it, except the Block Start and Block Stop. Now, I haven't done a dual range lines ever. So I looked for some resources on the methodology.
If I had points there are resources that will create it based on intersection points but I don't have that data.
I just want to make sure that my method is correct.
So the way I have been doing it is by putting an arrow on the middle of the street line to the right. I added green point for the start point and red point for the end point. This orientates the way I am facing down the line to make left and right distinctive. I then starts at the base of the line to then go to the end of the line. That creates my start address range and stop address range. This is the correct way of doing it?
Do anyone have a resource or example that I can use so I can learn and get this right?
