I have a web map that I created for use in Field Maps which I cannot edit the layer. It seems to be the setting in the web map that choose to use in Collector, Field Maps, or both. When the choice is both, I can edit the layer in Field Maps. However, if the setting is only Field Maps I cannot edit the layer. When only the Collector option is set, I can edit the layer in Collector.
I have tried uninstalling and reinstalling Field Maps. The version I am using is 20.2.0 build 271. I have an Android Active Pro tablet with Android version 10.
Is there some setting I am missing for a web map to only be used in Field Maps?
Thank you,
Kevin
