Hello. I'm having problems editing annotation in ArcGIS Pro 2.7. Specifically, problems editing the annotation attributes. If I go to Edit tab -> Select (and then select an anno) and then click Attributes on the Selection section of the Edit tab, the anno attribute dialog will open but it locks up. The more I try to click on the dialog the more it locks up ArcGIS Pro. To get control back I have to go to the Windows Task Manager and crash out of Pro.
Here's my process:
In Pro
Create a new map project
Add a layer of existing local data (lakes)
Create a new file geodatabase
Create a new annotation feature class in the new database (not feature linked).
Create a new annotation on the map
Select new anno if it's not already selected
Click the Attributes button on the Selection section of the Edit tab
The attributes dialog opens, and then the crazy starts to happen. I pretty much can't do anything after that other that crash out of Pro with the Windows Task Manager. It's hard to move the Attributes dialog or to do anything else in it.
Any ideas? .... Thanks!
