I find that the widgets are placed too far away from the ui borders consuming precious screen real estate.
I was hopping that it would be easy to customize using the scss theme files but not really. Below is the markup:
<div class="esri-ui" style="inset: 0px;">
<div class="esri-ui-inner-container esri-ui-corner-container" style="inset: 15px 15px 30px;">
<div class="esri-ui-top-left esri-ui-corner">
The margins from the ui borders to the widgets is defined by `style=inset: 15px ...` making it harder to override.
Why is the rationale of having this hardcoded ? Should it be moved to the styles instead ?
One workaround is to use the infamous `!important` on one of the class but the inner-container class is also used at some other location and it messes with the UI layout. Is the corner-container class the one to update ? I haven't found it used anywhere else. If it is the cases what about moving the positions (inset) there ?
