I am using a popup on my mapView from arcGIS API for Javascript 4.17. When the user opens the popup, I have set the following attributes:
view.popup.open({
// Set the popup's title to the coordinates of the clicked location
title: "Location Coordinates: [" + lon + ", " + lat + "]",
location: event.mapPoint, // Set the location of the popup to the clicked location
content: setContentInfo(view.center, view.scale),
actions: [risk_snapshot, ble_report, print_report, lidar_report]
});In the popup, I am adding some smaller maps using a function called setContentInfo that returns a "masterDiv" DOM node with the maps. However, I want to add an additional DOM Node outside of that div to the content. The function is essentially setup as below. How can you add multiple items -DOM Nodes to content?
function setContentInfo(center, scale) {
var popupDiv1 = document.createElement("div");
popupDiv1.classList.add("mapViewLeft");
var popupView1 = new MapView({
container: popupDiv1,
map: map,
actions: [],
center: view.center,
zoom: view.zoom,
scale:
view.scale *
2 *
Math.max(view.width / 250, view.height / 250),
constraints: {
rotationEnabled: false
ui: {
components: []
var popupDiv2 = document.createElement("div");
var popupMasterDiv = document.createElement("div");
popupMasterDiv.id = "masterDiv";
popupMasterDiv.style.width = "650px";
popupMasterDiv.style.height = "450px";
var theDiv = document.getElementById("masterDiv");
popupMasterDiv.appendChild(popupDiv1);
popupMasterDiv.appendChild(popupDiv2);
popupMasterDiv.appendChild(ble_report);
// Return a dom node
//return popupView.container;
return popupMasterDiv;
}To test, I have tried adding var test = document.createElement("div"); test.textContent = "Hey"; and then adding
popupMasterDiv.appendChild(test);
but it puts the "Hey" in the middle of the 2 maps. I also tried adding the above straight to the content like this:
content: setContentInfo(view.center, view.scale) + test,
But that removes the map content and only displays "Hey"
What I want is to add a nice little table in its own div under the maps with something like this. What am I doing wrong here; how can I achieve this:
var table1 = "<table id="info">
<tr>
<th>Location</th>
<th> </th>
</tr>
<tr>
<td>Coordinates</td>
<td>Parcel ID</td>
</tr>
<tr>
<td>123.345, -43.432</td>
<td>12345</td>
</tr>
</table>"
