Greetings,
I can return and loop through a list of Features that I want to export to a file gdb.
I can't add the gdb + Feature as a variable to export.
It fails in the arcpy.FeatureClassToFeatureClass_conversion(Features, outLocation, outFeatures) section.
I would appreciate any pointers, and/or links to help resolve this.
import arcpy
import arcgis
from arcgis.gis import *
from arcgis.gis import GIS
from arcgis.features import FeatureLayer
from arcgis.features import FeatureLayerCollection
import pandas as pd
## SET Parameters
arcpy.env.orverwriteOutput = True
arcpy.env.workspace = r"D:\Users\user\Documents\ArcGIS\Projects\Databases\SDE.sde"
datasets = arcpy.ListDatasets(feature_type='feature')
datasets = [''] + datasets if datasets is not None else []
print("START")
## output file
outLocation = (r"W:\My Documents\user\ENV.gdb\ENV")
inFeatures = ""
outFeatures = inFeatures
#### EXPORT DATA
for ds in datasets:
for fc in arcpy.ListFeatureClasses(feature_dataset=ds):
new_name = fc.split('.')[-1]
#print(new_name)
Features = ([new_name])
print(inFeatures)
The arcpy error message
RuntimeError Traceback (most recent call last)
<ipython-input-13-f520ea9e3f4b> in <module>
38 Features = ([new_name])
39 print(inFeatures)
---> 40 arcpy.FeatureClassToFeatureClass_conversion(Features, outLocation, outFeatures)
41
42 # outFile.close
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\conversion.py in FeatureClassToFeatureClass(in_features, out_path, out_name, where_clause, field_mapping, config_keyword)
2098 return retval
2099 except Exception as e:
-> 2100 raise e
2101
2102 @gptooldoc('FeatureClassToGeodatabase_conversion', None)
2095 from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
2096 try:
-> 2097 retval = convertArcObjectToPythonObject(gp.FeatureClassToFeatureClass_conversion(*gp_fixargs((in_features, out_path, out_name, where_clause, field_mapping, config_keyword), True)))
2098 return retval
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py in <lambda>(*args)
509 val = getattr(self._gp, attr)
510 if callable(val):
--> 511 return lambda *args: val(*gp_fixargs(args, True))
512 else:
513 return convertArcObjectToPythonObject(val)
RuntimeError: Object: Error in executing tool
Regards,
Clive
